Playtime_II
Jan 22, 2014Explorer
drill a small hole for the wires and seal with 3m 4200 or 5200. I opted to go a different route. I ran the control wires from outside (under the end of the LED strip into the overhead cabinet. Inside the cabinet the wires connect to the power adapter (110v to 12v). I just open the cabinet and pull the 110v plug out and into the receptacle on the underside of the cabinet. I did not want the LEDs on 12v. Too many things already drawing power when "off".
I taped the remote sensor to the glass so I can control from the outside. I tried inside but there are some codes that also control the TV.
38,768 PostsLatest Activity: Nov 21, 2015
