Disneyfix
Feb 11, 2014Explorer
Effy wrote:Disneyfix wrote:Effy wrote:
So I received the lights yesterday. Tested them here in the house. THey work great. The remote does not appear to require line of sight. I tested from all angles and distances and it works fine. The adhesive stio that came on it appears to be worthless but I can buy a roll of that. So one final question on the install. I planned on attaching them directly on the wall of the coach just underneath the awning. Originally I had thought about running the power lead inside the awning mounting rail as my outside receptacles are right there and a bin right below that. The only problem with this seems to be that the power lead is really short. The 4 pin connector to the remove receiver is only about 3" long. So I either have to run the lights themselves down through the awning rail, or make a lead. I have never worked with the 4 pin connector lke that but I imagine I could splice it and run a length of it. How did you giys mount yours? I'd rather not drill into the wall if I don't have to.
So did ya go off ebay or amazon?
Bought the lights off ebay $29.00 including shipping. I got the extension 4 pin cord from Amazon for $7.00.
Were they the 5050 outdoor model? Can the be spliced up into a few different sections and run into 12v light for instance? Or would I need a control box for each little section?
PS How did you guys get these tiny things to stay on the frame rails?
38,780 PostsLatest Activity: Nov 24, 2017
