crasster wrote:
Did it happen periodically when you turned it on and off? Or did you just leave it running and then suddenly you smelled it?
Well, when I smelled it initially when I turned it on, then it dissipated after a minute or so. But if I turned it off, then a while later back on, I smelled it again. Again it dissipates after a few minutes. I will say that I noticed it after about 24 hours of hard rain and a lot of it we drove in. Wonder if moisture is getting into the system, but like I said I am not sure where the intake is. Under the hood, same as the airbox for the engine or is there a dedicated filter/intake for the dash AC?
