Effy's avatar
Effy
Explorer II
Apr 21, 2014
Musty smell from dash vents
On a recent trip home I had to use the dash defrost to remove some minor condensation from the windshield. Not the type of moisture that happens when there is a buildup in the coach, just your typical cool weather windshield variety. Anyway, when we turned it on there was an immediate musty smell from the vents. This happened periodically throughout the day. Our new coach only has 7k miles on it and we've had it less than a year but I guess somehow some moisture got down in the vents. Is there a cabin filter or anything I can check/replace? Is there anyway to remedy this?
  • Effy's avatar
    Effy
    Explorer II
    bob213 wrote:
    Mine does that if it sits for awhile. I was told to turn off a/c a few blocks from home to let moisture escape. (don't know if this really works but...) I then used a product called FrigeFresh made by BG. I got mine at the Toyota parts counter. Sprayed that thru the outside intake with the unit running and the smell has not returned.
    Where is the outside intake? Same as the air cleaner for the engine? Sorry if it's a dumb question, I have had vehicles with a cabin air filter.
  • Effy wrote:
    I've never used my dash air. I only used the heat and defrost to get rid of some moisture or to warm up my feet.
    The front defroster runs the AC to dry the air out regardless of the temperature selection. There were some passenger vehicles that cycled the AC compressor no matter what mode or temperature the climate control was set to. My wife's old Taurus wagon was like that. I guess the idea was to always dry the air out. To my knowledge, that was a short lived practice.
  • The "dash air" is a system, a single unit with both heat and cool capabilities.
    Defrost does run the A/C compressor to dry the air.
    You should use the system more, more is always better.
    Find and ensure the drain is clear. Easiest way to find it would be to run the dash A/C until the water starts dripping out.
    As was stated they do have various chemicals you can squirt into the intake to kill and mold or other smeely stuff that might collect in the system.
  • Effy's avatar
    Effy
    Explorer II
  • A lot of people keep the AC on until they are at home or at there intended destination. This practice will lead to moisture being trapped in the vents. A safer practice is turning the AC off about one or two miles from stopping. This allows the system to dry out, thus cutting down on trapped moisture in the vents. Leave the fan on high, but cut off the AC.
  • Mine does that if it sits for awhile. I was told to turn off a/c a few blocks from home to let moisture escape. (don't know if this really works but...) I then used a product called FrigeFresh made by BG. I got mine at the Toyota parts counter. Sprayed that thru the outside intake with the unit running and the smell has not returned.
  • Plugged drain tube is my first guess. That seems to be the vast majority of the cases anyhow.
