RLS7201
May 12, 2015Explorer II
While looking at you last posted picture, it dawned on me that you will need different valve covers. The ones you have on the carbed heads won't work on the EFI heads. You'll need 1988 or later valve covers. Or does your long block come with valve covers? The EFI valve covers have center mounting bolts.
And while I'm jabbering. If you intend to replace the upper and lower radiator hoses, they are Motorcraft KM4941 for the upper and KM4969 for the lower. Rockauto.com is the best price source. Not shown for your 94 but 95 is the same. The little short hose from the cooler to the water pump is the same for all 460s (pick up) with oil cooler.
Richard
Richard
38,780 PostsLatest Activity: Aug 05, 2026
