Bird_Freak
May 12, 2015Explorer II
RLS7201 wrote:I know how to do it right. Been doing it for many years. How are you going to check total advance curve?Bird Freak wrote:RLS7201 wrote:Hope your arms are long enough to reach the distributor from the bottom of the engine while holding the timing light.:hjplante4 wrote:RLS7201 wrote:jplante4 wrote:
Isn't there another timing mark visible from beneath the RV? I thought they set another up for timing on #5. If not, maybe you should do it while you have everything apart.
That little piece of ingenuity was done by Chevy on the 454 for the P32 chassis.
No such luck on Fords F53 chassis.
Richard
Ingenious maybe, but it made timing an engine a 2 person job.
Some of us are capable of moving back and forth between distributer and timing light. Some not.
Richard
Why? I'm not a rookie, I'm fully capable of going into the MH and adjusting the distributer and then going under the MH and checking the timing again.
Now you know how to do it too.
Richard
38,780 PostsLatest Activity: Aug 05, 2026
