sailor_lou
May 15, 2015Explorer
rgatijnet1 wrote:
Concrete paving stones are useless and dangerous. In fact concrete blocks of any kind are terrible to use to support any vehicle. Concrete will fail in an instant with no warning and they are not designed to take a concentrated load, especially a load that can shift. Even when I used concrete in construction it was always with steel reinforcement and never with a concrete wall without poured and steel reinforced pilasters, lintels, and tie beams.
That is why you see house movers and other people that work underneath heavy objects using wooden cribbing to support the weight of the overhead object.
X a million !!!! The use of wood blocks under the tires is a much better option. Good luck and be safe.
Lou
05 Travel Supreme Envoy
38,780 PostsLatest Activity: Aug 05, 2026
