Mike_Hohnstein
May 17, 2015Explorer II
The transmission torque converter seal should be changed, with a quality replacement, unless you like to gamble. A word on pre-lubricating the engine, a pressure vessel, plumbed to the oil pressure sender port is the best way, drill powered oil pump spinner works too. Turning engine over with the spark plugs out is a last resort, what ever, pre-lube, I know you know that.
38,780 PostsLatest Activity: Aug 05, 2026
