turbojimmy
May 17, 2015Explorer
Mike Hohnstein wrote:
The transmission torque converter seal should be changed, with a quality replacement, unless you like to gamble. A word on pre-lubricating the engine, a pressure vessel, plumbed to the oil pressure sender port is the best way, drill powered oil pump spinner works too. Turning engine over with the spark plugs out is a last resort, what ever, pre-lube, I know you know that.
I used a drill and a dismantled distributor to spin the oil pump on mine until I had lots of oil coming out the push rods.
I rolled the dice on the trans. I unbolted it from the engine, slid the TC back and didn't mess with it otherwise. I figured since it was moving when the engine blew, if it ain't broke....
38,780 PostsLatest Activity: Aug 05, 2026
