davidharris
May 24, 2014Explorer
The water damage extends about 4 to 6 inches above the window and the wood is solid above that. The damage below the window is significantly worse than above so I don't think it was the roof. The delamination on the outside is only below the window.
I have removed the interior plywood, the foam core, and the loose plywood not stuck to the fiberglass below the window and some above the window. I am close to start cutting replacement wood and foam.
What is the best adhesive for the plywood to fiberglass and then to the foam and the internal plywood?
As for the window seal I am thinking about eternabond's putty but I know it can be a mess.
David
David
38,709 PostsLatest Activity: Mar 09, 2025
