MrTravelist647's avatar
Oct 04, 2014
My Future Home?
http://imgur.com/a/7wiv2
Hello all,
I'm new to the whole RV'ing thing, but I'm looking to jump in with both feet. I've been looking to purchase a motorhome that I could live in for the next few years while I finish my college education, and that I could take on the road after I graduate.
So far I've stumbled across a few that have caught my interest, but one in particular:
A 1981 GMC Travelcraft with a 350 engine (Chevy?), that only has 47,xxx miles. And I must say that she is beautiful (see above link). The current owner just recently (as of 10/2) had a new alternator installed, and an overall inspection done.
Anyway, the only concern I have is that the generator won't turn on. This was the only feedback that the owner told me after the mechanic called her to tell the results. I've tried to look up what kind of generator is in this machine, but to no avail. I'm looking for any information regarding this specific generator type, and also general ideas of whether this is an RV that a 20 year old young man could life in for the next few years!
Thanks for your time.
tl;dr
The generator on a 1981 GMC Travelcraft went out. What kind of generator would be able to replace it?
  • Did the odometers then read full mileage, or reset to zero after 99,999.9 miles? If it's the latter, it could easily be 100k or 200k over what it's showing.
    Generator is probably an Onan or a Generac. I don't know if a newer one will fit, but someone skilled (read high $$/hr.) needs to troubleshoot it first. Many generator issues are caused by disuse, and fixes can start about $300 and go up from there. Replacing with a new one, if possible & simple, will run $2.5K > $3.5K, maybe a bit more. A cheaper but hasslesome alternative is a portable on a cargo rack.
    Tires should be not over 6 years old, regardless of tread remaining. There are articles on the net on how to read the date code. They're probably 16.5", of which very few varieties are made any more, and freshly-made ones are hard to find.
    Check _thoroughly_ for soft spots in walls, ceiling, & overcab; rot caused by water leaks is the death of _many_ class C's.
    Finally, if you're in a northern clime, best forget 'living' in it. Cost to heat would be about as bad as rent, condensation & resulting mold might be unhealthy, and water system is very unlikely to be 4-seasons. _Not_ for the unskilled RV'er.
    Jim, "Mo' coffee!"
  • Eastern Washington in the winter? Good luck with that idea. Think in terms of 100 dollars a week for propane. 200 dollars a month for electricity. Frozen water lines. Frozen dump valves. All this on top of the RV parks 500 or more dollars a month rent.
  • Things to check are age of the tires. On an RV the amount of tread left on the tire is meaningless. An RV tire will rot and have a blowout causing lots and lots of damage. Any tire on that rig over 5 years old needs to be replaced. I say this because the tires are not covered in the pictures and the UV rays fro the sun is what rots the tires.
    Next is the refrigerator. An RV refrigerator is different than a household refrigerator. A new fridge can cost 1500 - 1800.
    The appliance you want to work the most is the fridge and RV fridges are set up to cool on both electric and propane so a small generator would serve to charge your batteries if the fridge runs on gas (Make sure you test)
    AS for the genny the cure could be as simple as filling the fuel tank. An RV genny will usually not start if the fuel tank on the motorhome is 1/4 full or less. It could also just be the carb is all varnished up from lack of use. A little work on your part cleaning the carb might be the cure. So I would not fret about that to much.
    You ask what kind of genny it could be and I believe it will have an ONAN generator of about 4000 watts.
    YOu do realize that if you are in cold climate you will probably not be able to live in it all winter as it will be almost impossible to keep warm. The older ones tended to have zero insulation. So the water lines will freeze, condensation will be a problem. You will go through huge amounts of propane. I would see if you can rig up a 100 lb tank so you can take it for refill.
    So what state and city will this be in
  • Do you have experience working on vehicles? Are you a quick learner in that area? No matter how well it has been maintained, any 1981 RV is likely to be one issue after another. Most may be minor, but some may be more complex. You have to stay on top of them. If you can fix them yourself, it will be fine. If you have to get them repaired, it will drain your college and travel fund. This is especially true if it has sat for a long time. A 30+ year old RV with only 47K miles no doubt has spent a lot of time sitting. I would actually be more comfortable with more miles on it at that age.
