msmith1199's avatar
msmith1199
Explorer II
Jun 23, 2015
My latest error on the motohome!
My latest mistake over the weekend almost cost me, but I really lucked out. The toilet was starting to back up a little and when you opened the valve, sometimes you would get a bubble back indicating some pressure build up in the black tank. I assumed that my roof vent may be blocked. So when it came time to pack up and empty the black tank I decided I'd try and do a really good clean out of it. So I ran quite a bit of water into it and then opened the valve and drained it out hoping to get as much debris out as possible. I closed the valve and left the water running and got distracted and forgot about it.
I was over on the right side of the motorhome when I noticed water start to drip from the roof. I had the A/C's running so I thought it was from them. Then all the sudden the flow increased to a small waterfall from the roof. As soon as that happened I knew exactly what I had done. I ran over to the other side and turned the water off as fast as I could and pulled the black tank handle at the same time. I was almost afraid to go inside the motorhome because I was anticipating that I had made a huge mess. But I went inside anyway and was very happy to see the toilet valve held! There was a little backup into the toilet but no overflow. So no mess and everything worked fine and if in fact the roof vent was clogged before, it is most certainly cleaned out now! I do not recommend that method for cleaning the black tank vent however.
  • Yup, those damn running hoses and distractions, get you every time....
  • As we get older we tend to forget things I have found. The biggest thing I forget to do is turn off the water when filling the fresh tank. Because of the pressure regulator it takes my tank probably 20 minutes to fill. So I always forget until I come out and see all the water on the ground flooding out my campsite.
  • I know I've seen this movie before! LOL!
    Glad it worked out OK Mr. Smith!
    I'm a slow learner but I now will not leave something on and start another project.....no catastrophes but I left a car running in the garage (door up) to charge the battery (old car) as it's not driven much. It ran for over an hour and then I remembered it was on.
    MM.
  • The real error would have been if my wife had flushed the toilet before I got around to pull the black handle as what was in it would have come up instead of gone down. Then I would have had to have thought real quick as to how I could blame her and tell it was her fault for doing something wrong! :)
  • Why is that an error?
    I bet you learned better first hand than reading any instructions.
  • I read his story and he heard a pop before water came off the roof. I'm betting his air vent really was clogged good and the damage to his toilet was done before the blockage popped free. Or his vent could have got clogged as the tank filled and something already in the tank clogged the vent line before popping free under the pressure. In mine the water just started to trickle, and then run freely so if there was a clog it came out pretty easily. I don't see any sign of damage to anything.
  • Major mess avoided.......hopefully no damage to black waste water tank like what happened to this RVr.
    LINK
