AikenRacer's avatar
AikenRacer
Mystery coolant leak stops vacaton
We were 2 hours into a 4 hour trip to the coast for a week. Received two alarms for low coolant level. Each time I added coolant to the tank. Gotta be a reason for it. I checked all the normal items, oil, leaks, water pump, etc. No leak anywhere. I called Cummins in Augusta. The mechanic said it could be the EGR cooler or the air compressor. Neither would you be able to see. He recommended to get the unit to the shop asap. So we turned around and drove home. Got the low level alarm one more time. Crawled all over the engine and saw no leaks. Taking it to Cummins on Tuesday. I did notice some signs of spray on my tow vehicle. Have any of you had a similar experience? Comments? Cost of repairs, etc.?
  • Do you have a coolant loop going into an aquahot or water heater? Could have a leak there.
    Like Ranger Smith said, Look for those 2 valves and shut them off.
  • Crawl underneath and there are 2 shut off valves near the chassis by the motor that turn off the front heater core and lines. See if that does it.
