JOERVDREAM's avatar
JOERVDREAM
mystery switch
I have a 2005 Winnebago sightseer 29r. In the cabinet on the right of the tv in the cab area is a button that when you push down a green light comes on and when you push it again the light goes off? Also the outlet plates in the cabinets next to the tv and also in the cabinet in the bedroom where that tv would be are black? There's one across from the refrigerator also? All the rest of the outlet covers are white and are in everyday use areas? An inverter was an option that the previous owner did not get. are these outlets pre-wired for a inverter?
Thanks
  • That should be the antenna booster as Dave stated. When ON (green light) you are able to pick up channels farther away. I've forgot to turn ours on once or twice, but could still pick up a couple channels. Once, in the SW, left it off and found no channels (far away from town). When back on, I got a few.
