enblethen
Nov 30, 2014Nomad
What chassis?
If you have owner's manual it should be in it. Many are rated at only 3500 and some at 5000.
You will also have to weigh your MH as if you were hitting the road then weigh and add the weight of your toad to get gross combination weight. The GCW should be on a sticker somewhere in the rig. Sometimes on wall by driver's door if equipped sometime in cabinet or closet.
If you still plan on towing the Avalanche from other posts, it may put you over both.
