map40
Aug 01, 2017Explorer
I rv wrote:
make sure you have power (shore power)to the inverter/charger and all connections are clean and tight.If the charger is bad,mine was,I got a 50 amp rv 3 stage charger from ebay for about $100.00 and just hooked it to the batt. lugs on inverter.I disconnected the 110 volts from the charger/inverter and and put a receptical in that bay plugged in the new charger and works fine and the intelec panel inside still works. good luck
So you just connected the charger to the batteries? I was going to do that, but I was afraid on the charger feeding power back into the converter. Any comments?
