Executive wrote:
Two pertinent points to consider:
1. For those worried about being stuck with no cell service, what would you have done 15 yrs ago..:h. If a police officer sees a rig on the side of the road 98% of the time they'll stop and check to see if you're ok. THEY have a radio!
2. When changing an outside dual or a front tire, the RIM does NOT have to be removed. Simply use the pry bar and remove the tire from the rim, leaving the rim on the coach. Reverse the process, air it up and you're on your way....Dennis
Case in point! Get a CB if you don't have one! Then go have a beer and make a sandwich!
