- FIRE_UPExplorer
bluwtr49 wrote:
I just spent a lot of time looking at options and what I found is that you can mix and match cameras and monitor to you hearts content. Virtually any camera with work with virtual any monitor, tv, or whatever.
I plugged my camera into the TV to see which was causing me a problem and it worked just great. In my case the camera was bad.
Well Sir,
When you say you can plug "any camera into any monitor", I'm not sure that's quite correct. You see, we have the Sony on our '04 Itasca Horizon, 36GD and, a proprietary, 6-pin-din plug was used for that application and, according to RVcams.com, Sony cameras, ONLY work, with SONY monitors, specifically because of that plug. Now, I'm by far, no audio-visual tech so, at this time, I can only say what they've told me. If you've developed "adapters" to use when plugging in non-like brand monitors and cameras, then I can see how your statement would apply. But, doesn't each maker of camera and monitor have their own plug? I've not tried other cameras or monitors.
Scott - bluwtr49Explorer III just spent a lot of time looking at options and what I found is that you can mix and match cameras and monitor to you hearts content. Virtually any camera with work with virtual any monitor, tv, or whatever.
I plugged my camera into the TV to see which was causing me a problem and it worked just great. In my case the camera was bad. - sch911Explorer
38,763 PostsLatest Activity: Mar 21, 2016
