Tom_M1
Jun 11, 2021Explorer
A 100 watt panel will do fine for just maintaining your batteries. You most likely will have a problem doing both the chassis and house batteries at the same time because typically there is a battery isolator in the system. You could jumper around the isolator while in storage. You will also need a charge controller. A cheap PWM type would work fine.
