n7bsn
Apr 14, 2013Explorer
Fleetwood E4 wrote:
I was reading up on a K&N website about a cold air intake system for my E450 v10 Class C motor home. They said "You could get 17.5 horsepower gain & 22 ft lbs of torque & a small increase of gas millage." I was wondering if anyone has done this to their motor home or is it even worth the cost? Any advice would greatly be appreciated. :@
As noted, I think the K&N is about the worst thing that you can add to your engine. There are many independent published tests that confirm that the greater particle size that the K&N allows in is a really bad idea.
What you have is the 2-valve, improved crank V10. This version was started in...2001, and is still being put in E350/E450 chassis. It is a rock solid engine.
The Banks headers system was a great addition on the older 460-V8, it has proven less so on the V10. Even less on the E350/E450 chassis where the greater heat it generates has caused issues with the poorer cooling the E series gets vrs the F series.
What does appear to give a boost is the a good engine chip. The best one is probably Mikes 5-star. I have yet (on any forum, including the V10 forum ) see any complaints about it.
You don't mention what the model year is. If you have the 4R100 transmission I would add a Banks Transcommand.
38,782 PostsLatest Activity: Sep 10, 2026
