Scars
Oct 03, 2014Explorer
RVNADA shows a value of $10,300 for both the Windcruiser or Sunflyer (with no options)
My main concern would be the engine/transmission...age and really the under use- 27 years old or less than 2k a year avg., which means its been sitting a lot.
Check date codes on the tires...when I test drove ours I took it to a local RV park and they let me plug in to test AC unit for free. It might be 50 amp since 2 ACs.
For around 20k you can get a V10 Ford chassis MH in the 2003 range with much newer/nicer amenities. If you're mechanically inclined, the Itasca could be a good starter unit. My long 2cents...good luck!
38,766 PostsLatest Activity: Jan 10, 2026
