sonbeau wrote:
We have a 33 ft Jayco Precept class A with hydrolic levelers and will be making our first long trip cross country. We will be boondocking a good share of the way. Should we have a set of jack pads and/or camco blocks with us? Just pads or both?
And, should the coach always be leveled before opening any slides?
Thanks for any input :-)
The subject of slide extension before or after leveling is debated on here and other RV forums weekly. About 98% of the time, the manufacturers of about 99% of the RVs out there, Class A or C, state in the owners manual to LEVEL FIRST then, extend any slides. The 1% that say the other way, is rare.
As for leveling and using blocks for either tires and wheels or, the jacks, is also a debate. Most folks that want good stability and, know how leveling with jacks only will effect frame and body elements, will use ramps or blocks to drive up on, then, will use added blocks under the jacks so the jacks do not have an extended travel to help fine tune the leveling and, make things as stable as possible.
But, that involves just a tiny amount of WORK and many don't have that kind of energy. Those plastic leggo type blocks seem to have quite a following. I have a set that I primarily use for step support. I've got a small lumber yard I carry for leveling. This is all a matter of choice and, how much one puts into a good, stable platform when you're done leveling. Good luck.
Scott
