Busskipper
Oct 04, 2013Explorer
Need Help - Basic G4 LED replacement light for the Coach
LED replacement lights in the RV - basic G4 ceiling lights with dimmers, when I had these installed they had 10 watt 12volt Halogens and they never gave off enough light for reading. As they began to fail I added 20 watt and they made it a little better. So the question is have you replaced any of your lights with LED replacements? If so what did you use?
I have been looking online to see what is available and have found a large number of options, which leads to my confusion. Just a few are listed below;
10 watt – 140 lumens – 1 watt
15 watt? - 240 lumens – 2 w
20 watt – 300 lumens – 3.25watts
All of the above are very expensive, in comparison to many similar found on e-bay, thus the dilemma, so many options, what’s a person to do.
So if you have used any of these lights how did you like them? If not what have you used and do you have a link?
Now for a question on the Lumens and Color number’s, what have you found that works for you – I tend to like a bright Daylight color 5,000-7,000K and more light than I need as they are Dimmable.
Are most people using the lollipop style or a corn row style?
Join in and give me your insight, much easier to read RVer's reviews than to order 5-10 different units and decide.
Thanks for all the info,
