goufgators's avatar
goufgators
Need help....
This is in regard to an '05 Itasca on an '04 F53 Ford chassis. Now the problem: I've lost ac power to the 110 outlets for the front tv and for the rear tv. All other ac outlets are working. I've checked for a tripped breaker in the ac box and there are none tripped. These two outlets were installed specifically to provide power for the TV's and the sat. dish. Because the two outlets are both out, there has obviously been a break in that line/circuit. But, I'm at a loss as to where to find the culprit problem. Any ideas, advice, counsel?? Thanks, Larry
  • goufgators wrote:
    Bumpyroad wrote:
    are any of these GFI outlets/circuits
    bumpy
    Bumpy: Good thought but no they are not GFI.
    they don't need to be. check all of the RV for a tripped GFI and I bet you solve the problem. don't forget to check storage bays, too.
    bumpy
  • Don't know what type inverter you have but most have resettable circuit breakers that control separate circuits. Check them and also most MH will disable the power to the TV's when the ignition switch is on. On my MH this relay is mounted adjacent to the TV receptical.
    Blessings KDK
