John_Wayne
Dec 15, 2016Explorer II
Is this your first RV is the salesmans switch usual by the door on??? Do the batteries test over 12 volts?? Can you plug into 120 volt power?? If you can get 120 volt power you should be able to get 12volt inside and the the batteries should start charging. Can you start the motorhome? if so start the motorhome us the booster switch to start the generator the generator will power the charger to give you lights and charge the batteries.
