DrewE
May 10, 2020Explorer III
pianotuna wrote:
I'd recommend replacing the converter if it is bad.
With a converter that old that has separate charge and convert outputs (as suggested by it having a bypass relay that switches when it turns on and off), it would be a significant upgrade to replace it with a modern multi-stage converter regardless: it would provide cleaner DC output, charge the battery much more quickly, and probably generate less heat and hum doing so. The DC distribution panel would need a very simple modification to join the "filtered" and "unfiltered" busses together.
38,780 PostsLatest Activity: Aug 05, 2026
