Ivylog
Mar 01, 2014Explorer III
Yes I have power inside as the light works and the extra inside fan runs when the thermistor is hooked up. I'm usually able to run it on 5 even when it's really hot out.
*Did a Ohm/temp test on the old thermistor and it's 9K at 85 and goes all the way up to 60K when I put it in the freezer at 15 which means it's testing good.
**Using the door display test mode and hooking the new thermistor back up it registers a fin temp of 32 on test #3 confirming that it's good too. I'm starting to think a new control board is in my future.$$$
38,769 PostsLatest Activity: Mar 31, 2026
