IvylogExplorer IIIMar 01, 2014Need help Norcold 1200 with a Amish cooling unitUnit is not cooling well, 6-10 degrees on back wall of the freezer and fins above 34. By disconnecting the thermistor it will freeze things in the refer section in less than 20 hours. Had the correct ...Show More
darsbenExplorer IIMar 01, 2014If the wiring to thermistor were bad disconnecting it should have no effect on cooling
Related ContentNorcold 1210 Not CoolingAmish Cooling UnitNorcold cooling problemchanged out Norcold to Amish cooling unitAmish cooling unit installed
