nemo45
Mar 04, 2014Explorer
DSDP Don wrote:
Ivylog....Sorry...I didn't mean to side track the post with the residential refer.
I did a BUNCH of stuff to my Norcold to make it perform at a reasonable level. Something I learned by accident was there are two different thermistors for that refer. I was cruising websites looking to buy a thermistor one day and found a site that asked for the serial number. Apparently, there are two identical looking thermistors for the Norcold, but different part numbers. I ordered the correct one and my refer worked well again for awhile. Sorry, I can't remember the website.
I also added two additional computer fans to the exterior and one of the double fans to the interior. In weather under 90 degrees the refer would stay about 34 inside, but NEVER kept ice cream frozen, even though it made ice quickly.
As I said, sorry about distracting the post, but the Samsung was the best single improvement ever in my coach. All of the people on the Monaco forums installed it with the MSW inverter and four batteries and are doing just fine. I also think your idea of the costs to convert are a little high. You can get the SS model for $1209 OTD. If you can do your own install, just a few dollars in parts. Your charger issues don't make sense to me and if it's not working properly it seems it would be an issue for other things in your rig.
Ivylog, I too apologize for getting off topic. I was just trying to convince you to quit putting good money after bad with the Norcold and bite the bullet and get the Samsung. You, won't be sorry. I agree with DSDP Don. The Samsung was the best single improvement we did to our Tour Master. I tried the computer fans in the back and the one inside and there was some improvement. But still when it got up around 90 deg. the temp inside the refer would go up to at least the mid 40's. I tried changing the fin the thermistor was on to no avail. A repairman told me that if the thermistor was bad it would get too cold in the refer. He said my problem was a weak cooling unit. Basically, I just got tired of fooling around with the No Cold. After looking at the charts that are in the Xantex manual the 3 stage inverter charger will not put out close to 100 amps until the batteries (which would be two of them) get down to 11 volts. At 50% battery charge I think 30 to 40 amps would be proper. The fact that it is a 3 stage charger would be the reason the charge rates would change after charging for a while. This is also evident in the charts that are in the manual. And finally, $1209 is exactly what I would have paid for my Samsung without the $60 delivery charge. I know its a hard thing to do when you've already spent the money on the Amish cooling unit, but we sure love ours.
38,769 PostsLatest Activity: Mar 31, 2026
