IvylogExplorer IIIMar 01, 2014Need help Norcold 1200 with a Amish cooling unitUnit is not cooling well, 6-10 degrees on back wall of the freezer and fins above 34. By disconnecting the thermistor it will freeze things in the refer section in less than 20 hours. Had the correct ...Show More
CA_TravelerExplorer IIIMar 04, 2014OK, I was wondering what unit you had as the Magnums also have under charging issues.
Related ContentNorcold 1210 Not CoolingAmish Cooling UnitNorcold cooling problemchanged out Norcold to Amish cooling unitAmish cooling unit installed
