bgholson
Dec 10, 2013Explorer
If I understand your question correctly, you will need to attach a 2x4 board on each side of the cabinet. Then cut a piece of plywood to cover the existing opening and it will screw into your 2x4s. Attach the TV mount to the plywood before attaching to 2x4s. Leave cut outs in the plywood for attaching TV cables. Hold the TV up to the attached plywood, attach cables and then put TV on mount.
38,766 PostsLatest Activity: Jan 10, 2026
