wa8yxm
Aug 13, 2014Explorer III
Would use of these tires be determental... Depends .. In my case likely yes, since they are narrower and slightly smaller in diamater they will have LESS rubber on the road.. This means you need MORE PSI to hold up the motor home and I am running the max.
in your case, without running the rig over a scale and getting the 4 corner weights, And then comparing the weights to the tire's PSI requirements and max load. No way to tell.
IF the tire is up to carrying your RV.. then the Semi Tire will give a slightly rougher ride.. Somethine I very likely would never notice.. But you might.
