Ivylog
Aug 13, 2014Explorer III
Without weighing your coach, NO. Do you know how much pressure is needed in your front tires? Until you know this you cannot go to an 11R22.5 as it does not have as much load carrying as a 295/80/22.5. I'm running Hankook 11R22.5 on the back of my MH (which I like) and I had to increase my rear pressures by 10 psi over the 295's I replaced. On the rear this was not a problem as I was only running 85 in the 4 drive tires and 75 in the tag. There is only a slight change in speedo readings... not enough to worry about.
NO WAY could I run 11R22.5 on the front and I even went with 315/80/22.5 on the front over the original 295 that required 110 psi for my weight. On a previous DP I put Toyo on and liked them.
Brett, how are you finding the time to post on here... OK you're on tomorrow.
