Noel
Oct 31, 2015Explorer II
Need help switching old CRT tv with new flat screen
Did a search but not a lot came up. (Could be me). We have two old 2003 CRT TVs in front and bedroom. Front is not in a cabinet. Has plastic trim on the bottom and a steel cage and tray holding it in place. (As I have been told. Not looked, yet). Bedroom TV is screwed into a frame at the bottom and everything is inside a finished cabinet,with no door.
We have a 2011 Winegard Trav'ler SK003 which does not, I think, receive HD signal. So that means I can buy two LCD/LED TVs that are not HD. But if they come with HD...they will work just fine. Is that right?
Probably 720 x 480 is good. And a 60 Hz refresh rate.
I read on this forum about sound and sound bar tips; viewing angle and the three tuners needed. Also an audio out would be good. Smart TV would be overkill for us Luddites.
For the bedroom TV in existing cabinet (opening is 22.5" wide and 19.5" tall): I have asked around and looked at pics on RV forums and it seems a hardwood plank a bit wider can be attached with a piano hinge and the TV can be bolted to the plank with a wall mount or similar. It will open upward so stuff can be stored behind the TV. Maybe a small hydraulic arm would help. A quality latch or magnets will secure TV when driving. So far, so good ?
Front TV needs a good handyman or cabinet person to do this for me. I am not good at woodworking. After cabinet is constructed and mounted....the same procedure as for the bedroom TV will be used. Sound reasonable ?
I need to replace the old 2003 DirecTV receiver up front and also get a new receiver for the bedroom which does not have one now. I will probably go to a local RV service center and have a lot of this done including cable upgrades if needed and maybe I even need a new cable for the new receiver going into the bedroom. (The bedroom TV now gets only the same picture as does the front TV)
Vizeo and Samsung brands mentioned many times. I am leaning towards Best Buy's Insignia brand as they have excellent 160 degree viewing angles. Plus a 5 year service contract will cost me $40.
As you might deduce, I am not the best in consumer electronics or carpentry....so go easy on me when you reply.
Thanks
Thanks
