Sam Spade wrote:
David0725 wrote:
the only thing he had on was the A/C
There should not be ANY high draw devices ON when the generator is first started.
And are you saying that the cord going to the trailer is a "normal" household type plug ??
AND...if you have the normal situation, where the RV has a 30 amp cord and you are plugging it into a household 15 or 20 amp outlet......you should not EXPECT it to run the A/C.
The breaker is doing it's job by preventing you from overloading the outlet and possibly starting a fire.
