DSDP Don wrote:
You don't say what you're trying to power with the generator. You need to make sure that you don't have an electric water heater turned on, battery charger on coach/trailer turned on while trying to power other things.
This.
The breaker trips because of too much current draw, that is, too many things plugged it and running.
IF the breaker holds with nothing plugged in, the gen is probably OK.
Outside chance the breaker itself is bad but probably not.
I have a bad habit of forgetting to turn the A/C off when changing power sources.
You probably are drawing too much current because of too many things turned ON or because one of the devices is defective........or a fault has developed in the wiring.
