DutchmenSport
Nov 22, 2013Explorer
If you put pink stuff in your fresh water tank, you might not have enough to pump yet. There's always some on the bottom that never drains.
Also, if you did not by-pass the water heater, it's filling up with pink stuff and will not start pumping to the faucets until it's full (6 gallons).
What probably happened, if you did not bypass the water heater, you've already pumped out evrything in the fresh water tank and the water heater is not full yet. So the pump is pumping air now.
38,769 PostsLatest Activity: Apr 03, 2026
