calamus
Nov 22, 2013Explorer
Your pump is air locked do you have a suction hose that by passes the fresh water tank you should never have to put anti freeze in your fresh water tank (waste of money) if you dont have a by pass hose go buy one unscrew the suction side and put the hose on there stick it in a gallon jug of pink and suck a little in you may have to pour it in the line to get the pump primed. I also just blow the lines out now saves a ton of wasted time and money.
38,769 PostsLatest Activity: Apr 03, 2026
