prism
Oct 14, 2013Explorer
n4hwl wrote:
I have a 2004 Phaeton made by Tiffin. My left rear turn signal light is not working. I assumed that the bulb was burnt out. I checked it and the turn signal bulb is fine. I checked and found there is no 12 volt getting to the turn signal fixture when the left signal is activated. Ok Where so I go from here? I though there was probably a connector that had come loose. I am yet to find a loose connector. Is there a fuse that controls only the left turn signal? The right turn signal is working fine. Any suggestion would be appreciated.
Ken
Not sure if its the same system but there is(on my 2008 Allegro bus)a secondary flasher relay that runs the left rear turn signal and a seperate one that runs the right rear and I beleive each one is also fused seperatly.Its a sparton Chassis.Also maybe change your heading to turn signal from "tail lite"
38,768 PostsLatest Activity: Jan 26, 2021
