FIRE_UP
Oct 14, 2013Explorer
n4hwl wrote:
I have a 2004 Phaeton made by Tiffin. My left rear turn signal light is not working. I assumed that the bulb was burnt out. I checked it and the turn signal bulb is fine. I checked and found there is no 12 volt getting to the turn signal fixture when the left signal is activated. Ok Where so I go from here? I thought there was probably a connector that had come loose. I am yet to find a loose connector. Is there a fuse that controls only the left turn signal? The right turn signal is working fine. Any suggestion would be appreciated.
Ken
Ken,
Just wondering, do you have separate turn signals from your brake lights? As in, do you have "Amber" turn signals? If not, and your turn signals and brake lights are combo units, do your brake lights work on both sides? If, you have combo units, as many of us do, and, both brake lights work on both sides, then the circuit that energizes that filament of the left bulb, which is the same circuit for the turn signal is working.
That is, it's working when in the "NO Turn" situation. If a turn is in action, then the circuitry is changed due to the position of the turn lever in the column.
But, this is all presupposing you have combo units. If you do have Amber turn signals, then, that's a whole different animal. There should be fuses for each side of the turn signal system. If you have manuals, as in chassis manual or, a owners manual for the coach itself, you may find the location of the fuses there.
I don't know if any of this info will help you but, I thought I'd throw it at ya.
Scott
38,768 PostsLatest Activity: Jan 26, 2021
