1SG wrote:
I am having the same problem with my ME 2012. I called a recommended tech and he told me it may be the internal transfer switch. I will be taking the unit to him within the next couple of days.
Same error code?
Actually I'm wondering why both of you don't have AC. I would expect that the ATS would default to the AC input. After all it's just a relay.
I'd try this, perhaps call Magnum first: Disconnect the DC and see if that allows AC on the output. If you do this be safe: Remove the negative DC cable from the battery, then the positive cable from the unit and secure it very well, then reconnect the battery cable.
But these are temp patches and in the end it will need to be repaired.
