Hi,
The tankless units for RV's need to be propane fired as even a 50 amp rv only has 12000 watts to "play with". I prefer to use a ten gallon unit that would be 120 volt electric and propane.
Since I'm in a class C, when my water heater fails I'll try to upgrade to a "motor aide" unit that uses waste heat from the engine to heat the water in the tank.
mikebreeze wrote:
So I am now deciding on replacing my conventional 6 gallon hot water heater with the same device or going with a tank-less hot water heater. Pros that I have read for the tank-less include instant, unlimited hot water and less weight for the device itself. Cons include more expensive price, the faster the flow, the cooler the water and excessive start up spike in current. Has anyone here replaced their hot water heater and which route did you go? Thanks in advance.
