rgatijnet1
Jan 23, 2021Explorer III
Sometimes people run "G" tires because that is what is in stock at the dealer. I believe "G" tires are more common than "F" at some dealers. For the SAME load, the tire pressure is the same for "F" "G" or "H" tires so I doubt if you will notice a rougher ride. The higher load rating tire just gives you a little cushion if you might overload your tires.
38,782 PostsLatest Activity: Sep 10, 2026
