lawrosa
Apr 30, 2017Explorer
Your a lucky man to have what you have. There is no reason you should of killed those batterys.. I am so jealous..
That invertor has all a adjustable charging parametrs.
I would tweak them . For example default for bulk charge shows 14.6. I would change that to 14.8 or what your batterys recommend.
Example my duracells want 14,7 bulk and 13.8 float per the duracell spec sheet..
Here is the manual for your control panel. Id be in heaven if I had this equipment..
This unit does so much.. Im overwelmed...
There are so many settings that someone may have messed them all up..
Like max amps allowed
Charging voltages
Absorption times
Size of battery bank
Type of batterys etc etc
The list goes on..
http://www.magnum-dimensions.com/file/2228/download?token=uQ0vrM5l
Charging voltages
Absorption times
The list goes on..
