hikerman
Sep 13, 2016Explorer
need new tires
Have an '08' Monaco 35ft Cayman and the tires are dated '07'. In the market for Michelin or Toyo. Read good things about Toyo m154, but in my size 255-70R.22.5, it is replaced by Toyo M120. Do you...
J-Rooster wrote:Just want you to know ****** was not a swear word! The word I used starts with a R and ends with a D.
If your a member of or if you join FMCA ($25.00 per year) you can buy Michelin Tires at a discount thru the FMCA/Michelin Fleet Tire Program. I did this and saved a lot of money then going to a regular tire shop (Plus I did not have to pay for tire shipping). I run Michelin XRV's on my RV but, have run Michelin XZE on my Peterbuilt before I retired. I liked and had good luck with both sets tires. The difference between these tires are the XRV's are made from a softer rubber to fit RV applications (RV's sit a lot therefore softer rubber sidewalls and tread enhance tire wear) The XRV's also have a UV ray material to ****** the Sun and sidewall cracking. The XZE is a hard rubber truck tire. I ran a loaner truck with Toyo tires (when my Peterbuilt was in for service) and liked them, there also a hard rubber truck tire. Michelin and Goodyear are the only two tire manufactures that build soft rubber tires for RV applications. All other tires are hard rubber truck tires (FYI). Good Luck with whatever you buy.
