Jim
Dec 20, 2013Explorer
RCtime wrote:
I just mounted a spare 32 Vizio in my guest bedroom. The Vizio weighs about 36 pounds. The bracket is rated up to 70 pounds.
I wouldn't use this bracket in my rv as it wouldn't be rated for any decent dip or bump in the road.
How much do you guys want to over engineer the weight rating to actual tv weight to accommodate any possible hard bumps.
A frost heave sneaked up on me in Alaska once that would have been a good test.
Once the arms are folded up against the backing board, I don't worry about it. Plenty of strength above the rating of the bracket as it's rating is for the full weight with the arm(s) extended.
Naturally, I wouldn't drive around with the TV extended.
38,778 PostsLatest Activity: Jun 06, 2026
