mrlightrail's avatar
mrlightrail
Need replacement hose assembly
Got a 91 Pace Arrow Class A, and the hose that goes from the manual fresh water fill to the tank is broken in many places. Right now, I have duct tape slowing the leakage when I fill the tank. I've checked on Camping World, but cannot find a replacement hose. Any suggestions on where I can find one?
  • RoyB's avatar
    RoyB
    Explorer II
    Take the hose with you to LOWES - You should be able to come up with something to replace it.
    Roy Ken
    its just water hose most likely 1/2 inch
    you can buy 1/2 rubber hose almost anywhere
    I should clarify my post.My answer was based on what a diesel pusher MH uses that has the city water or tank fill position switch valve
    these use commen 1/2(ID) style water hose.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    The hose, in fact ALL hoses, have 3 parts.. A connector that hooks to the valve, a connector that goes into the tank, and the hose.
    On my Damon, the hose is a standard piece of flexible hose, mine is clear with white threads embedded, every hardware store from here to there and back again has it...
    Just take the hose to any hardare, Lowes, Home-Depot, Mennards and so on and they can cut you a hose of the proper length.. a pair of automotive style hose clamps (they will have those too) and the job is finished, this is NOT a high pressure hose.
