HelloImDavid
Nov 14, 2013Explorer
Thanks everyone for your help. Im going to go to NAPA first and look thru their shelf selection and if that dont work...then ill contacts VelVac . If that fails, then ill go with regular mirror glass hopefully cut to exact size.
By the way, Ive found out that regular mirror glass is highly reflective whereas auto mirror glass is far less reflective plus you can actually see thru it when held up to light. Ive had two Glass Shops tell me that you arent supposed to use regular mirror glass for a sideview mirror because its easy for the DRiver to be blinded by reflection if the sun hits it directly. Just a heads up.
