EvExplorerAug 23, 2016Need slide out helpArrived last evening at RV resort leveled the coach, went to open slides they moved very slowly and stopped about two inches from being fully open won't come back in either will only move one inch in ...Show More
EffyExplorer IIAug 23, 2016Are you plugged in to shore power and have you checked the volts on your batteries? This sounds like a battery issue.
Related ContentEasy way to remove slide topper?arctic fox slide adjustmentslide out 120v harness issuesSchwintek slide jammed - shifted backslide vs no slide
