wrgrs50s
Apr 01, 2018Explorer
Thanks for the link enblethen, that looks like the replacement there. The old one had what looked like a condensor attached to it also, it was green painted as the generator so it was factory. It was attached to the mounting bracket and went to the positive side. I was puzzled because it also had one that looked new attached to the negative side. Any idea what these are and why they were necessary.
Matt, The coil is firing on one output side but not the other side using the same spark plug and wire to test. Using my test light the input on the positive side lights up and stays on while cranking and the negative side pulses while cranking. According to a diagnostic chart I found, this means that the input voltage and module pulsing is good. Now I didnt think to check the plug gap itself as it had ran fine with the plugs previously.I sure thank you and welcome any other ideas.
38,766 PostsLatest Activity: Jan 10, 2026
